8.1 yukon
Old Feb 19, 2010 | 06:43 PM
yukon25008.1's Avatar
Registered User
Question 8.1 yukon
I have an 04 yukon xl 2500 8.1 4l85e, besides the tune, intake, and exhaust imthinking i would like to do a mild cam, justnot sure what should or has to go along with it, i have the identical 8.1 siiting in the shed for a project so if i had to i could use the heads from it to get sent out for some minor work, i checked with jegs about a comp cam, and they said minor head work might be required but roller rockers definitly, just looking for some advise
Old Feb 19, 2010 | 08:13 PM
brent5631's Avatar
I don't know much about an 8.1 but I wouldn't trust to what I heard from jegs.
Old Feb 19, 2010 | 09:43 PM
acethedragon's Avatar
jegs races too but take advice with a grain of salt. need to find some guys modding their 8.1s and see what works. not much goin on there cause of the head setup. no way to put carb intake on it and only a couple make performance parts. head are just outrageously priced. good luck with wat ever you decide. its a torque monster
Old Feb 19, 2010 | 10:24 PM
james8997's Avatar
i havent heard much about them either, but good luck with your build
Old Feb 20, 2010 | 12:28 AM
1Bear's Avatar
Comp has a handful of cams listed for the 8.1L, but even though none of them are listed at having over 0.513” of lift, the Extreme Energy versions are listed as requiring converting to an adjustable valve-train (hence Jegs telling you that your heads would need machine work).
Extreme Energy cams:
XR258HR 206/212 .510/.510 112deg. operating range of 800 to 4800rpm
XR264HR 212/218 .510/.510 114deg. operating range of 1000 to 5000rpm
XR270HR 218/224 .510/.510 114deg. operating range of 1200 to 5200rpm
Their line of Tri-Power Extreme cams does not mention having to modify your heads for an adjustable valve-train, but I would check with Comp for any additional information.
Tri-Power Extreme cams:
TPX246HR-16 194/206 .500/.493 116deg. operating range of 600 to 4600rpm
TPX254HR-15 202/212 .507/.500 115deg. operating range of 800 to 4800rpm
TPX262HR-14 210/218 .513/.507 114deg. operating range of 1000 to 5000rpm
As the others have said, good luck with your build. It should be a Torque Monster!
Old Feb 20, 2010 | 06:39 AM
Registered User
thanks so much 1bear for the listings and help, im definitly not taking jegs advise, i just called them to see about the cam, i dont want to get treal crazy with it but definitly want a step farther the intake,tune,,
Id be really really happy running a 12 sec 1/4 mile with the kids watching barney in the back...
Old Feb 20, 2010 | 06:41 AM
Registered User
Also the more i look around i see some 8.1 pickup guys with nitrous, that 8.1 is such a strong motor the nitrous probably doesnt present a problem does it
calsdad
Jun 14, 2023 11:07 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
mayko
Sep 7, 2015 12:24 PM
