Repeated lifter failures
Old Sep 15, 2021 | 11:33 AM
  #21
Geotrash's Avatar
Originally Posted by dsmmace
One question I am curious about, what oil are you using?
Amazon Basics 5W-40 Euro-spec synthetic most of the time but had Mobil1 5W-30 in it both times it let loose.
Old Sep 15, 2021 | 11:37 AM
  #22
shakenfake's Avatar
Shlumpt
5 Year Member
Yessir that Amazon basics power!
Old Sep 15, 2021 | 12:08 PM
  #23
TXsilverado's Avatar
Is there a new Amazon oil that i should know about? I run Mobil 1 10w30 here in the south on everything I own, but it's getting harder and harder to find the standard labeled green capped bottles at walmart anymore. Everything I find now is "high mileage" "oil leak stopping" "racing" "advanced fuel economy" "ultra all round" "20K miles performance" "annual protection"
Just give me the OG bottle of ******* 10w30 with no BS marketing **** that has always worked 100% of the time!
Old Sep 15, 2021 | 12:26 PM
  #24
shakenfake's Avatar
Shlumpt
5 Year Member
Yeah there are some Amazon Basics oil that are normally a bit cheaper
I think this time round I’ll run Castrol. It seems to be $4-$5 cheaper for 5 quarts.
Old Sep 15, 2021 | 12:30 PM
  #25
darkirish63's Avatar
I think it would make sense with the cam and extra spring pressures to run something 5W40 weight and possibly an zinc/moly oil additve. I run Rotella T6 5W40 personally, but oil is VERY opinion based.
Try ZR1 Racing oil. Already has zinc in it. I run 5W40 in my stroker all year long. Best oil for performance engines with bigger cams.
Old Sep 15, 2021 | 12:32 PM
  #26
Originally Posted by Geotrash
I almost bought Johnson lifters but have a buddy who just replaced his 6 month old Johnsons with Morels because his Johnsons wouldn't pump up in the morning until he was half way to work. I told him to take a Viagra and leave a half hour later. Lol.
Never had a problem with Johnsons not pumping up.
Old Sep 15, 2021 | 09:05 PM
  #27
Geotrash's Avatar
Thought y’all might appreciate seeing a video of the difference between the lifter trays that I received from Vinci and a GM factory lifter tray. This is conclusive evidence to me as to why my lifters, and ultimately my cam swaps failed, twice. Conclusion: use new GM trays only.
Old Sep 15, 2021 | 10:13 PM
  #28
1FastBrick's Avatar
Custm2500's Rude Friend
Exactly why they failed!!! No matter how old the GM lifter trays are even when used, they should never rotate. If they do, they are JUNK!!!
Old Sep 16, 2021 | 08:50 AM
  #29
out of curiosity, why did you decide to go aftermarket for the lifter trays on such an inexpensive part?
Old Sep 16, 2021 | 09:36 AM
  #30
Geotrash's Avatar
Fair question. Mainly because I trusted the seller. Roger Vinci is a pretty well-known name in valvetrain engineering, so if he told me they’re good trays, I was prepared to take him at his word. And, he claims that they’re genuine GM trays, but clearly they’re not. :-(
