ready for a cam swap
Old Feb 16, 2014 | 02:59 AM
Dcomo's Avatar
Default ready for a cam swap
Ive an 07 crew cab sierra wit the 6.0. I plan on pullin the engine in the future an overhaulin and possible adding a pro charger. I have a 8" lift wit 22" rims wit 35's. Its a daily driver but not sure what size cam to go with. Any suggestions
Old Feb 17, 2014 | 02:40 PM
Dcomo's Avatar
Any sugestions??
Old Feb 17, 2014 | 02:44 PM
trxmxzx's Avatar
13 Second Truck Club
I'm thinking isky triple 12 cam myself - when I have the money
Old Feb 17, 2014 | 04:11 PM
Z71crawford's Avatar
Your best bet would be to call someone and get a custom spec cam.
Old Feb 17, 2014 | 06:41 PM
Dcomo's Avatar
jus wonderin z71, why would it have to be a custom specs cam? couldnt i jus order one from speed shop or jegs etc
Old Feb 17, 2014 | 06:46 PM
gamble686's Avatar
The trickflow 216/220 would do just fine and is super affordable.
Old Feb 17, 2014 | 07:02 PM
Dcomo's Avatar
tks gamble, now will that cam work for my procharger upgrade.
Old Feb 17, 2014 | 07:54 PM
69Camaro427's Avatar
A lot of people run a split patter like mentioned above for sc, while smaller single plan cams are favored for turbo aps. In general, honestly boost likes the stock cam pretty well, so it will like almost any cam other than stock "within reason" with a good tune.
I assume from your large wheel/tire configure set up you would like to gain some lowend and midrange. I like the 216/220 idea, keep low end, and give more mid/top over the stock cam. If you want a top end screamer go bigger.
Old Feb 17, 2014 | 07:56 PM
gamble686's Avatar
Yes it has an appropriate split duration and 114LSA so it should do very nicely if your not looking for an all out build.
