quick cam question
Old Jan 11, 2007 | 08:01 PM
tarinitup's Avatar
9 Second Truck Club
Default quick cam question
Would It be worth $250 going from a 224/224 cam with .567 lift to a 228/230 with 272 lift or should I just spend the money elsewhere.
Old Jan 11, 2007 | 08:17 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Would you go to a higher stall too? Planning on swapping intake?
Old Jan 11, 2007 | 08:26 PM
tarinitup's Avatar
9 Second Truck Club
I want to keep the same stall and truck intake so if it requires a bigger stall to work right then I'll just keep the current.
Old Jan 11, 2007 | 08:39 PM
trever1t's Avatar
My TT3000 was barely enough for the 224 cam I had. I would think a cam that big would want a 3600 rpm or so. As I understand it, the truck intakes are limiting. That cam is going to give peak hp up higher than usable.
Old Jan 11, 2007 | 09:17 PM
tarinitup's Avatar
9 Second Truck Club
I forgot to mention its for a 6.0 not 5.3
Old Jan 11, 2007 | 09:25 PM
onebadrubi's Avatar
That cam a 3600 converter and ls6 intake would def be a 400hp setup IMO. in a 6.0 that is with other suporting mods.
Old Jan 11, 2007 | 09:35 PM
tarinitup's Avatar
9 Second Truck Club
I should just ask if the 228/230 is better than a 224/224 for overall power on a 6.0 with mods in sig.
Old Jan 12, 2007 | 01:25 PM
tarinitup's Avatar
9 Second Truck Club
I just ordered the 228 cam and will sell the 224 cam next month.
Old Jan 12, 2007 | 01:51 PM
virgils4.85spd's Avatar
Default Please let me know when you sell
the 224 cam! im lookin for a good used one. What brand is it, lsa, and mileage.
Thanks,
Derek
Old Jan 12, 2007 | 03:34 PM
tarinitup's Avatar
9 Second Truck Club
comp cams 224 224 with .567 lift on 112 lsa, 11,000 miles
