Question on Power difference between high compression and low compression N/A engines
Old Oct 6, 2009 | 03:53 PM
Mangled03gmc's Avatar
Baltimore Whore
A point of comp is good for 3-5% in hp...
Old Oct 6, 2009 | 03:55 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by GMCtrk
1 pt is about 4%. so your down about 8-10% in power.
I wonder what comes between 3 and 5
Old Oct 6, 2009 | 03:58 PM
Baltimore Whore
Yah I read it over after i posted it.. But guess it must be right since more then one of us posted up on it.. So you keep watching your movie you freak...
Old Oct 6, 2009 | 04:47 PM
Michael Halo's Avatar
350-375 because of the 80e and small cam...
Old Oct 6, 2009 | 07:30 PM
charcold-bowtie's Avatar
I dont think hes too worried about the numbers anyway. Its bee proven a high horse boosted motor
Old Oct 6, 2009 | 07:42 PM
Spoolin's Avatar
GFYS and STFU
Yup yup! Not really worried what it makes to be honest, I know next spring it'll be in the 8xx hp range but right now trying out all these different combo's and seeing how they react is interesting!!
So assuming a normal stock compression 6L with all the bell's and whistles would make 400rwhp - 10% cuz of the low compression I'm looking at maybe 360rwhp...could be close! I'm still shooting for under 360rwhp though!
Old Oct 6, 2009 | 07:46 PM
Spoolin's Avatar
GFYS and STFU
Originally Posted by 00ChevyScott
If you dyno 320 rwhp, you need to burn that thing to the ground...
Originally Posted by twolow02fransen
im sayin youll do at least 350 RWHP liked stated above if yoiu dont make at least that then something is wrong IMO
That could be very likely, considering I can't even be trusted to put a brake pad on the right way who knows what else I fucked up!!
The intake faces the firewall right?
Old Oct 6, 2009 | 07:50 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
What power adder are you going with?
Old Oct 6, 2009 | 08:01 PM
Spoolin's Avatar
GFYS and STFU
when I know more and that it will work I'll let you know, till then I still have more research to do.
Old Oct 6, 2009 | 08:03 PM
1slow01Z71's Avatar
*reaches for ban button*
