Question on cylinder honing
Old Jul 25, 2016 | 08:17 AM
Tigger Welder's Avatar
Default Question on cylinder honing
I am building an LQ4 for my suburban, replacing the 5.3
I have a new stock ring set and am wondering what grit hone to use. Had someone tell me the factory doesn't recommend the dealers hone at all if they freshen an engine. That sounds odd, but I am not used to these low tension rings.
Thanks in advance for the help.
Old Aug 8, 2016 | 09:22 AM
Nobody gonna offer any advice?
Old Aug 8, 2016 | 10:49 AM
Feed's Avatar
320 or 400 is what I came up with searching on ls1tech. I went with 320.
Old Aug 8, 2016 | 10:56 AM
Thanks! I'll do it! Searching on here was not very productive.
Old Aug 8, 2016 | 11:00 AM
mvrk10256's Avatar
Iron Cylinder Ring Type:
OEM Iron rings: 180 or 240 grit
Chrome rings: 240 or 320 grit
Moly Rings: 320 or 400 grit
Plasma Rings: 320 or 400 grit
not sure ring type: 240 grit
Manufacturers Recommendation:
Hastings: 240 grit
Akerly & Childs (Ductile Iron): 240-280 grit
Akerly & Childs (Moly): 400 grit
Perfect Circle (Ductile Iron): 240-280 grit
Perfect Circle (Moly): 400 grit
Sealed Power (Moly): 400 grit
Speed Pro Hellfire (Ductile Iron): 240-280 grit
Total Seal (Ductile Iron): 240-280 grit
Total Seal (Moly): 320-400 grit
Harley Davidson(stock): 320 grit
Wiseco (chrome top): 320 grit
Mahle (Moly/Chome top): 280 grit
source
Old Aug 9, 2016 | 03:27 PM
Thanks, the whole don't need to hone didn't sound right, but that is why I asked. Glad the world is still turning! Now lets get this sucker put together!
Old Aug 11, 2016 | 06:43 AM
94_C/1500's Avatar
Registered User
I wouldn't hone it yourself unless you have the real tools. Otherwise go to a machine shop. Wouldn't hurt to get it magnafluxed anyways.
chaosz71
Mar 29, 2016 05:21 AM
06murder
Feb 23, 2016 12:41 PM
NHolds
Feb 19, 2016 01:37 PM
mallards
Sep 30, 2002 09:16 AM
Looney Booney
Aug 11, 2002 03:40 PM
