Question on cylinder honing
I am building an LQ4 for my suburban, replacing the 5.3
I have a new stock ring set and am wondering what grit hone to use. Had someone tell me the factory doesn't recommend the dealers hone at all if they freshen an engine. That sounds odd, but I am not used to these low tension rings.
Thanks in advance for the help.
Iron Cylinder Ring Type:
OEM Iron rings: 180 or 240 grit
Chrome rings: 240 or 320 grit
Moly Rings: 320 or 400 grit
Plasma Rings: 320 or 400 grit
not sure ring type: 240 grit
Manufacturers Recommendation:
Hastings: 240 grit
Akerly & Childs (Ductile Iron): 240-280 grit
Akerly & Childs (Moly): 400 grit
Perfect Circle (Ductile Iron): 240-280 grit
Perfect Circle (Moly): 400 grit
Sealed Power (Moly): 400 grit
Speed Pro Hellfire (Ductile Iron): 240-280 grit
Total Seal (Ductile Iron): 240-280 grit
Total Seal (Moly): 320-400 grit
Harley Davidson(stock): 320 grit
Wiseco (chrome top): 320 grit
Mahle (Moly/Chome top): 280 grit
source
Hastings: 240 grit
source
