Pushrod length checking. I've never done this before and I am overwhelmed by myself
Old Mar 10, 2014 | 02:58 AM
j.mo's Avatar
Default Pushrod length checking. I've never done this before and I am overwhelmed by myself
I've never attempted and internal engine mods myself and I'm overwhelmed with it.
I have got to get this done this week, and I'm doing the project by myself.
Cam and heads on an 04 silverado with the 5.3
243 heads milled .030 and a comp 214/222 .560 .569 111 cam.
I have no idea what size pushrods to use and after reading until my brain is fried I'm no more understanding about the process than when I started.
My truck has to be smogged and ca registered in a few weeks, I have to remove my long tubes, and solve the p0300 code that came on yesterday. I don't want to do work twice, so while in the process I'm going to do my cam/head swap.
Someone please help!
Old Mar 10, 2014 | 03:14 AM
j.mo's Avatar
Also, does anyone think my truck will pass smog with that cam and heads in California?
Old Mar 10, 2014 | 07:07 AM
Atomic's Avatar
I have a gauge for that
Get one of these: http://www.summitracing.com/parts/cca-7702-1/overview/
Adjust it until you take up all the slack in the rocker without opening the valve or compressing the lifter.
Old Mar 10, 2014 | 10:47 AM
Jeebalow's Avatar
Here are some posts I found useful.
https://www.performancetrucks.net/fo...shrods-505622/
https://ls1tech.com/forums/13174477-post7.html
Edit- I also used this for the head/cam swap on my 5.3, but looked up a few things elsewhere along the way (e.g. Rocker torque sequence, intake torque sequence, etc.) Also read a post that somewhat discredited the site so do some research first. I'm sure others will chime in if this is way off.
http://www.ls1howto.com/index.php?article=2
Old Mar 10, 2014 | 12:07 PM
Atomic's Avatar
If you see that "count the turns of the rocker bolt" method, completely igonore it.
Old Mar 25, 2014 | 03:59 PM
Derek Riley's Avatar
What length did you end up using ?
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
