Pretty Noob question here
Old Feb 25, 2010 | 05:53 PM
THE-HOE's Avatar
Default Pretty Noob question here
when looking at cam specs and it says something like 224/225 589/591 111+4... What does the +4 mean? install the cam 4 degrees advanced? What are the reasons for doing this?
Thanks
Shane
Old Feb 25, 2010 | 06:16 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks
Shane
The +4 means that there are 4* of advance ground into the cam, which will help bring the meat of the torque curve on sooner
Old Feb 25, 2010 | 07:21 PM
THE-HOE's Avatar
Ohh i get it so its already ground into the cam.. Thanks! So would the cam i have listed above be good for a turbo application? I was told it is specked for a turbo, but the low LSA scares me because most turbo cams i see have at least 113 and up.
Old Feb 25, 2010 | 07:51 PM
budhayes3's Avatar
PT's Slowest Truck
I'm no turbo guru, but the LSA looks too tight from what I'm used to seeing for boosted applications, like you mentioned, they're usually 114 at the least
kyle's v
Oct 4, 2015 12:37 PM
713truck
Aug 18, 2015 09:32 PM
Bluchevypick
Aug 18, 2015 09:11 AM
black00chev
Aug 12, 2015 01:56 PM
USMCvet0311
Aug 1, 2015 07:45 AM
