ported 241's on a lq4?
Old Mar 22, 2009 | 08:12 PM
Default ported 241's on a lq4?
found a good deal on some ported 241's and wanted to know if the chamber size with mine being 4.00 in bore and the 241's being 3.9 would that work if so would it be worth the swap would be doing a ms4 at the same time ?
Old Mar 22, 2009 | 08:25 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
It will work. What are the specs on the heads?
Old Mar 22, 2009 | 08:30 PM
dirt track racer 81's Avatar
i had hand ported 241s on my lq4 with a 230/226 cam..
GMCtrk's Avatar
I was recommended against ported 241s in favor of 243s or 317s. Better combustion chamber design on the latter I believe
Old Mar 22, 2009 | 08:40 PM
well 297 and 205 at .600 28x 200 at .550 is what he said.
Old Mar 22, 2009 | 08:42 PM
how did it run ? I have a ms4 sittin in the living room and these heads come with prc duals and titanium retainer for 300 shipped.
243s are what i have on my 370 now..in all honesty id go with a 317 head and have them milled .040 and still be around the same compression as the 241 head..but yet since the ones hes wanting to buy are ported..might be best to go with them
GMCtrk's Avatar
that's a lot of flow for a 241. I'd like to see that verified with a flow sheet.
Old Mar 22, 2009 | 08:43 PM
GMCtrk's Avatar
Well, the nice thing about non milled 243s is no worry about PTV clearance. He's got an LQ4, stock 64.45cc 243s would be perfect, bringing compression to a nice 10.6:1
Old Mar 22, 2009 | 08:45 PM
351rwhp on a loaded mustang dyno and got to 12.56 in the 1/4 with a 2.00 60ft.
only got it to run it once with the new intake before my rear end started actin up
