port and polish my heads when doing my cam installatioin?
Old Jun 8, 2007 | 12:37 AM
Richard@WCCH's Avatar
FormerVendor
Originally Posted by xdanny510x
im going with a 224/224 .568* 114lsa cam
custom cam
so intstead of getting the 7.400s go wit the 7.350?
should i run a 3000 stall? cause i was planning on hold off on the stall
Use the stock length pushrods and at least a 3000 stall. If you try to run the stock converter your truck is going to be a dog under 2500rpms. I think you'll have an impossible time trying to get your engine to idle in gear with the stock converter and the 224º cam.
Good luck,
Richard
Old Jun 8, 2007 | 02:44 PM
xdanny510x's Avatar
do i really need the larger valves or can i stick with the stockers?
Old Jun 8, 2007 | 11:38 PM
FormerVendor
Larger valves (especially the intake) will show great benefits in increased power due to the relatively large cross sections in the stock 5.3l intake ports. IMO the larger valves are a big help to 5.3l engine performance gains. Given the amount of work to remove and install the heads I think the extra $196.00 for the larger valves is justified.
Richard
Old Jun 9, 2007 | 12:00 AM
Spoolin's Avatar
GFYS and STFU
My god it's like a fountain of knowledge in this thread. I think I'm going to open up a shop right next to yours richard and steal your buissness.
"WCCCH" (West Coast Custom Cylinder Heads)
Old Jun 9, 2007 | 12:51 AM
moregrip's Avatar
what a rush!
that's where the Balance Shop is, try again
Old Jun 10, 2007 | 12:36 PM
Silver-Dollar's Avatar
Right next to my titleloan business.
Old Jun 11, 2007 | 12:24 AM
Flaco's Avatar
8 Second Club
if you want to keep your 7.400 pushrods and save an extra 140 (if u already have hardened pushrods) bucks or so. shim the bottom of the rockers .050 or so to help with the oil control onthe tip of the puushrod at high rpm's.
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
bbowerman
Jul 26, 2015 10:57 PM
jmarkway
Jul 18, 2015 09:23 PM
4B11T
Jul 13, 2015 03:48 PM
