polluter cam ?
Old Jan 18, 2009 | 05:05 PM
Wilde Racing's Avatar
How do I change this text
not yet, he plans on a running a huge shot later this year...
Old Jan 18, 2009 | 06:10 PM
nah im hoping to get in the 11's with the n2o before the cam I might just do some ls2 243's first to get my compression up and the decide on the cam I never expected to run those numbers on a stock lq4 my prediction before we got there was 13.50's but man was I wrong.
Old Jan 19, 2009 | 12:05 AM
the_husk's Avatar
With his 3600 rpm converter and nitrous, it should work VERY well.
Old Jan 19, 2009 | 12:58 AM
cowl327's Avatar
+1 With ALL of the supporting parts it would be great,but youll need a 3k plus stall,gears,headers,better intake....you know what i mean....
Old Jan 19, 2009 | 01:47 PM
Sales2@Texas-speed's Avatar
Former Vendor
That cam produces HUGE torque down low for a big cam, more in line with high 220's duration cams.
Show us.
Old Jan 19, 2009 | 01:56 PM
maddboost's Avatar
What cam would you recommend for a "torquey" setup in a truck Matt using a 6.0 motor?
Old Jan 19, 2009 | 06:17 PM
the_husk's Avatar
Originally Posted by Matt@Texas-Speed
Show us.
There's a graph floating around on ls1tech.com
Old Jan 21, 2009 | 04:03 AM
silver-mod-o's Avatar
Hunt&Fisherator
Edit: to be exact, already is producing around 375rwtq BY 4000 rpms, and around 330rwtq at 2500rpms. If anyone were looking for a big cam, that would be the one to get, AND, it doesn't need to be spun any higher than 6500 rpms, actually by 6000 its starting to level off, just a slight increase, pretty much flat.
Since when is that "big down low torque"??
Granted my setup is different but with the 5.3L, small cam and very low boost I was well over 400rwtq by 3000RPM and carried that up to 5250 (where the graphs crossed) and it make a peak of 517 well before that....
37xlb/ft on a 6L is in no way impressive.... There's n/a 5.3s here that make just about that.... You don't need the biggest donkey dick cam you can find to make power hp or tq either one....
Old Jan 21, 2009 | 08:35 AM
the_husk's Avatar
It's got WAY more torque down low than my buddies torquer V3. But then again, his car lacks torque all OVER the place, peaked at 343. With his stall, he would be right where he needed to be with thtat cam, plus he has a 175 shot, so it would work VERY well.
Old Jan 21, 2009 | 08:47 AM
Hunt&Fisherator
It may work well, with a 4000 converter... But either way, those numbers aren't anything to write home about.
