Pistons out
Old Nov 18, 2012 | 01:26 PM
phasemaster1's Avatar
Default Pistons out
Pulled the pistons and everything looks ok. No broken lands and rings look good also. Is it normal for piston skirt to have wear scuff marks? I found a little nasty black film on pan it sparkles so think its from lifters and cam they have abnormal wear like hardening was bad. Bearings ok I guess not really sure but looks like normal wear no copper. At this point should I check the main bearings also? This is the furthest Ive been in an engine so I have read alot but no experience makes it a little tough to know what is ok. Thanks
Old Nov 18, 2012 | 08:10 PM
Byrdman11's Avatar
All sounds ok. post pics of bearing and stuff.
Old Nov 19, 2012 | 11:10 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
A little wear on the skirts are normal, however I agree some that some pics would definitely help judge...
Old Nov 25, 2012 | 08:22 PM
Here is a picture of the piston thats suspect, looks alittle worse than picture shows.
Old Nov 25, 2012 | 10:02 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The one behind it looks a little worse...
Old Nov 26, 2012 | 05:37 AM
TXSZ66AVLANCHE's Avatar
Completely normal looking but I would not reuse them. New 5.3 pistons are cheap.
Old Nov 26, 2012 | 03:55 PM
actually the one in the front has a spot where it has more damage almost like a small flat spot
Will do when the time comes but for now going 6.0l
Old Nov 27, 2012 | 11:07 AM
Truck Sponsor
That wear looks normal, does the cylinder wall itself have any scuffing?
Old Nov 28, 2012 | 09:55 PM
No they look good except for #8 has a vertical scratch barely can get my nail to catch.
Old Nov 29, 2012 | 11:31 PM
Truck Sponsor
If you can feel the scratch with your fingernail, usually the rule of thumb means that it would at least need a hone.
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
