pistons?????
Old Feb 22, 2006 | 05:22 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Default pistons?????
where can i get some 5.3 forged pistons????? what web site what part number thanx
Old Feb 22, 2006 | 07:24 PM
TurboGibbs's Avatar
try diamond piston, JE piston, and Mahle. They all have the best selection of off the shelf LSx pistons. You may have to have some custom made for the 5.3. I don't recall seeing any off the shelf for it.
Old Feb 22, 2006 | 08:25 PM
Low_LSX's Avatar
Default well
am getting a t76 turbo and 4.10 and a cam so0o0o i need forged pistons o0f the shelf......................even if i bore it its ok
Old Feb 23, 2006 | 12:08 AM
FarmerBeau's Avatar
Sexy Party Mod
yeah you can bore the 5.3 over to a 346 (ls1 bore). you will just have to bore it out and the rods and crank are the same as the ls1. good luck
Old Feb 23, 2006 | 01:03 AM
Low_LSX's Avatar
how much over can i bore it what piston size ??
Old Feb 23, 2006 | 01:24 AM
TurboGibbs's Avatar
3.898 is stock ls1. You can safely bore a 4.8/5.3 block to LS1 bore. Anything in the 3.898-3.905 range should be fine.
Also, if you are using a stock rod you need pistons for a .945" wrist pin and 6.098" rods. The 6.125" .927" wrist pin are an aftermarket gen 1 sbc rod that is often used in LSx engines. Due to quality and weight my preferences in order would be Mahle, JE, then Diamond. Lighter is better of course and Diamond's are all heavy. I am putting diamond in my 6.0 but they were the only thing off the shelf that I could find in my compression range I was after. They are nice quality though.
Old Feb 23, 2006 | 01:26 AM
Low_LSX's Avatar
do i need to do some head work??
Old Feb 23, 2006 | 01:31 AM
TurboGibbs's Avatar
You could do a little clean up on them if you'd like. It is just all what you have as far as a budjet goes. With FI you can get away without spending as much money on the heads due to the gains not being as dramatic as with a NA application.
Old Feb 23, 2006 | 08:21 AM
Low_LSX's Avatar
thanx alot
Old Feb 23, 2006 | 11:48 AM
Yellowsierra's Avatar
thanx alot
I went with the Mahle -16cc pistons and im happy with them so far and the customer service is good.
