piston to wall clearance
Old Apr 25, 2018 | 01:32 PM
bottledls6's Avatar
Default piston to wall clearance
So I have a L92 block had 92k on it. Machined it, cleaned it an had it honed. Stock pistons going back in it. I have .00250-.0030 of clearance between the wall an skirt, is that ok to run or am I looking at aftermarket pistons.
Old Apr 25, 2018 | 04:07 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Depends what your going to do with it.
Old Apr 25, 2018 | 04:54 PM
bottledls6's Avatar
N/A and maybe nitrous later down the road
Old Apr 25, 2018 | 05:02 PM
1FastBrick's Avatar
Be a little on the loose side but should be no problem may cold start knock from piston rock. Make sure you gap the rings if you are going to spray it.
Old Apr 25, 2018 | 05:38 PM
bottledls6's Avatar
Will do. Thanks for the input
BigKID
Mar 24, 2014 06:00 PM
sand man
Nov 14, 2012 12:15 PM
beastmode
Dec 26, 2008 03:58 PM
IslandTahoe
Jun 5, 2003 10:27 PM
