Valve to Piston Clearance; Finding TDC
Old Jun 5, 2003 | 07:52 PM
IslandTahoe's Avatar
Default Valve to Piston Clearance; Finding TDC
Will be installing a cam soon.
Is there any way to check valve to piston clearance w/ the heads still on? By what method?
What about finding accurate TDC w/ heads still on the block?
Thanks
Old Jun 5, 2003 | 10:13 PM
Default Re: Valve to Piston Clearance; Finding TDC
I don't know of any accurate way to check piston to valve clearance without removing the heads but finding true TDC is easy if you have a degree wheel and a piston stop,just rotate the motor both directions to the piston stop half the distance between the place it stops in both directions is true TDC.You can set the degree wheel pointer there as the starting point to check your valve timing.If you are degreeing your cam you'll need a indicator dial to check the opening and closing points.
Old Jun 5, 2003 | 10:17 PM
What is a "piston stop'? Probably have seen one, not familiar w/ that name.
Old Jun 5, 2003 | 10:27 PM
Take an old spark plug and wield a small piece metal long enough to contact the piston on to it.
pittman
Jan 19, 2016 07:06 AM
lycominghunter
Aug 15, 2015 12:26 PM
DrX
Aug 11, 2015 07:25 AM
4B11T
Jul 13, 2015 03:48 PM
Mzay
Jul 6, 2015 11:05 PM
