piston to valve clearance ? for Lq4 going together
Old Mar 16, 2008 | 12:17 AM
hirdlej's Avatar
Default piston to valve clearance ? for Lq4 going together
I have a question for you guys regarding piston to valve clearance. I am running a stock lq4 shortblock with -8cc dish pistons, .041 head gaskets and a set of 243 casting heads milled .025". My question to you guys is I'm going to be running a 218/224 .590/.600 114 +2 cam. What I'm wanting to know is has anyone put anything like this together and if so, is, was, or will there be enough piston to valve clearance without having to flycut the pistons? I don't exactly feel like doing this and I'm contemplating redesigning the camshaft with less lift if I have to. Any input is appreciated.
Old Mar 16, 2008 | 10:34 AM
bluecajun5.3's Avatar
11 Second Truck Club
with all those specs you included you shouldn't have to worry about ptv clearance. however i would check anyways. also lift doesn't have anything to do with it, it's the duration you have to lookout for.
Old Mar 17, 2008 | 01:12 PM
hirdlej's Avatar
ttt ne1 else running a combo similar to what I'm putting together?
natejk
Nov 15, 2016 08:05 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
zraffz
Sep 8, 2015 07:40 PM
11MPG
Sep 8, 2015 04:52 AM
bisqikss
Sep 8, 2015 03:35 AM
