Piston Squirter....
Old Apr 7, 2009 | 03:13 PM
JAVI05's Avatar
pretty neat !!!! thanks for that info.
Old Apr 7, 2009 | 03:25 PM
A Low Dime's Avatar
13 Second Truck Club
Originally Posted by Wilde Racing
...had piston squirter, I've been searching for some pictures ....
Apparently making piston squirters ...... hmmm.... give Brian nutter a call....
Call Brian Nutter and ask about piston squirters?
Old Apr 7, 2009 | 04:26 PM
skyhighsami's Avatar
no title here
Wouldn't the engine block have to be disassembled and out of the vehicle to install these? Maybe if you have a block being assembled then sure why not do it, to go through the trouble of adding this to an engine up and running I wouldn't think it would be worth it.
Old Apr 7, 2009 | 04:32 PM
WJ MARK's Avatar
My old PT Cruizer turbo had the oil squirters. that thing ran 20 psi all day long and no issues. I think its definately somthing to look into.
Old Apr 7, 2009 | 04:33 PM
Bill Reid's Avatar
I think I remember reading about these first in the Soltice Turbo motor... before the LS9. Not sure if thats right but it sure does sound like it might be a good option if scratch building a motor... squirters aren't too bad in price from Katech... just wonder what the machine work cost is. "Cool" stuff
Old Apr 7, 2009 | 05:10 PM
Wilde Racing's Avatar
How do I change this text
Brian nutter works for wiseco, I would want to check with him to make sure there would not be any problems usingbthe squirters with my currant pistons.. And yes the engine would be comming back out and apart
Old Apr 7, 2009 | 06:05 PM
Spoolin's Avatar
GFYS and STFU
Are you typing on your Iphone again? you sound like my retarded and deaf little sister!
Old Apr 7, 2009 | 06:51 PM
Lolll mayfbe
Old Apr 7, 2009 | 08:11 PM
budhayes3's Avatar
PT's Slowest Truck
The Lexus LX460 has oil squirters for the underside of the pistons, I got to see a shortblock dis-assembled not too long ago...
Old Apr 7, 2009 | 08:21 PM
1Bear's Avatar
I would imagine one would also need the higher capacity oil pump from the LS9 to cope with the controlled oil leak that would be introduced.
