Piston Squirter....
Old Apr 7, 2009 | 08:32 AM
Wilde Racing's Avatar
How do I change this text
Default Piston Squirter....
Ever sence I head the new ZR1 vette had piston squirter, I've been searching for some pictures and wanting some for the older engines....
Then I found GM-high tech had a short add for Katech. Apparently they have started making piston squirters for the gen 4's...... hmmm.... Anyone with a big HP build got any plans on using them???? I'm going to look into the "slight machine work required" and give Brian nutter a call....
Old Apr 7, 2009 | 09:04 AM
BlackGMC's Avatar
Resident Retard
errr, what do the "Piston Squirter" squirt? oil, gas, laffy taffy? Sorry i have never heard of them before.
Old Apr 7, 2009 | 09:08 AM
Avalanche2002's Avatar
They squirt oil onto the underside of the piston to provide additional cooling for the pistons.
Old Apr 7, 2009 | 09:12 AM
BlackGMC's Avatar
Resident Retard
interesting, thanks clearing that up. So that was a NO on the laffy taffy? j/k...
Old Apr 7, 2009 | 09:37 AM
KySilverado's Avatar
Yep saw those trick little pieces on the LS9. Thought it might not be a bad idea.
Old Apr 7, 2009 | 09:52 AM
Yea, the squirter sprays engine oil on the bottom of the pistons to remove heat.
Pretty standard on turbo diesel engines.
Old Apr 7, 2009 | 10:17 AM
philntx's Avatar
Integral piston squirters in the crankcase oil galleries were essential in making the LS9 live under prolonged high boost. "Our analytical tools told us early on we would be in big trouble without them," says Jim Cremonesi, DRE (design responsible engineer) for the LS9 cranktrain. "We see a significant drop in piston-dome and pin-boss temperatures. It's the best way we know to pull the heat out of the piston when making this much power."
Katech versions:
https://ls1tech.com/forums/generatio...squirters.html
Old Apr 7, 2009 | 10:33 AM
Mmmmmmmm, prolonged high boost..............
Old Apr 7, 2009 | 10:37 AM
thunder550's Avatar
High on diesel fumes
Take your truck out to the salt flats. I wanna see a standing mile top speed of 170 or better.
Old Apr 7, 2009 | 02:25 PM
Ummm 135 is fast enough...... Of course that was in town.. LOL
