Patrick G spec'd cam Check it out
Old Mar 28, 2010 | 10:00 PM
SLO TRUCK's Avatar
he knows his ****. I would take his advice.
Old Mar 29, 2010 | 06:52 PM
jhe2003's Avatar
Originally Posted by iamkeniff
id rather that on a 114+3 imo but thats just me an i honestly dont know what you use the truck for or what you want out of it.
what stall from Circle D?
what gears?
The truck is used as a daily driver and I really don't want a lopey idle at all, I want a smooth idle but just a little bump in power.
Most likely it will be a reworked TB converter and I'm keeping the 3.42's
Originally Posted by tarinitup
what is it going in and what mods? I run one of his cams and am pleased with it.
Is going in my ext cab- mods are; LQ9, cold air int, long tubes and full exhaust.
Originally Posted by dirt track racer 81
I wouldnt run that with 918s..
I've been reading a lot about the 918's and most likely will be change to PACs
Originally Posted by slow n low 4.8
hmm that makes me wonder?
you gonna dyno it after the cam swap?
Wonder what the power diff will be between yours and a off the shelf 212/218?
I am just not a fan of big lift and stock heads,maybe this will make me change mind and opinion
You got a lq4 i see in your sig
LQ9 I will do some dyno runs before and after to see how the cam does.
Old Mar 29, 2010 | 06:56 PM
jhe2003's Avatar
oh and some bigger injectors too, I doubt the stockers will keep up even with this cam
Old Mar 29, 2010 | 07:01 PM
00ChevyScott's Avatar
Wearin' da big hat
Should run good for a DD.
Old Mar 29, 2010 | 07:05 PM
Jokeman's Avatar
You will be happy. I have one of his spec'd cams in my LQ9. I had him set it up for torque and the truck is a stump puller for being a gasser.
thewrx
Aug 12, 2015 08:28 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
NuckenFuts
Jul 9, 2015 08:45 AM
