parts list help please
Old May 1, 2014 | 10:47 PM
stroker87's Avatar
Default parts list help please
well I been getting parts for my turbo build over the last few months right now I have the following parts
317 assembled heads CNC ported
3-12 isky cam
manley harden push rods
Deka 60# injectors
Comp upgraded trunnion rocks
LQ4 block fresh out of the machine shop
05+ pistons & rods
piston rings
main & cam bearings
ARP rod bolts
this is what I i'm ready to order from ColoradoSpeed
LS7 lifters
LS9 head gaskets
LS2 lifter trays
gen3 studs
ls2 timing chain
ls6 oil pump
oil pan gasket
front cover gasket
front cover seal
rear cover gasket
rear cover seal
water pump gaskets
valley cover gasket
valley cover grommets
valve cover gaskets
exhaust manifold gaskets
coolant tube gaskets
block plug kit
gaskets are all GM brand as well as the timing chain, lifters & oil pump the studs are china
is there any thing I over looked "or" I should change? this is going to be a mild boost build 10 to 12 psi in a 04 RCSB
looking to place the order by the end of the day tomorrow 5/2/14
BTW if any one has feedback on ColoradoSpeed i'd love to here it I never used them before
thanks
Old May 2, 2014 | 06:13 AM
Chevy_King1500's Avatar
be sure to measure your push rod length!
Old May 3, 2014 | 08:29 AM
Beatdown Z's Avatar
Laid Back
That list looks good to me!
Old May 4, 2014 | 11:54 AM
69Camaro427's Avatar
Could check out ws6 store and see if they are cheaper, plus orders over $100 have free shipping.
03chevytruck
Nov 7, 2016 04:43 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
5.3Caprice
Nov 7, 2015 08:56 PM
BlackGMC
Aug 18, 2015 01:11 PM
Mzay
Jul 6, 2015 11:05 PM
