oil pressure
Old Sep 27, 2010 | 10:42 AM
one fast ss's Avatar
Default oil pressure
I just built a new motor with a mellings high performance pump. I now know the right o-ring was put in and everything was put together by a good shop. The truck rain mint for a few days then all of a sudden the oil pressure was going all over the place. from 0-45 at idle. I change the sending unit and it worked awesome after that. tonight however it started doing the same thing again. Any Ideas guys?
Thanks Adam
Old Sep 27, 2010 | 01:14 PM
baSICK5.0's Avatar
check the oil level. Mine does that every few weeks then i add 4 quarts of oil and it stops
Old Sep 27, 2010 | 04:26 PM
budhayes3's Avatar
PT's Slowest Truck
If it was good after you changed the sending unit, the problem may be in the connection to the sending unit, and by disturbing it you allowed it to make contact again. Check the wiring to the connector and the terminal inside the connector itself and make sure that it isn't spread out.
Old Sep 27, 2010 | 07:46 PM
03_Denali's Avatar
What he said... or the gauge.
Old Sep 27, 2010 | 11:25 PM
get a mech gauge on there and check it
Old Sep 27, 2010 | 11:28 PM
i slapped a mech gauge and pressure seems fine. so Im on to the wiring thanks guys
Old Sep 28, 2010 | 06:02 AM
03_Denali's Avatar
may be the cluster... My cluster "freaks out" every now and then
Old Sep 28, 2010 | 06:53 AM
baSICK5.0's Avatar
I think all of them do. My damn fuel level...Nevermind I dont even have to say it.
Old Sep 28, 2010 | 11:02 AM
budhayes3's Avatar
PT's Slowest Truck
I believe that the 03-04 models are especially problematic...
Old Sep 28, 2010 | 11:48 PM
yeah ive read all over that they've had problems with there gauges
Texas5.3_1251
Mar 5, 2016 08:10 PM
69z-28
Sep 21, 2015 07:31 AM
Go5.3tt06
Sep 14, 2015 02:11 PM
Brandonlflr12
Sep 8, 2015 09:01 PM
Boyes50
Sep 8, 2015 12:06 PM
