Now I'm having problems with pushrod length
Old Jan 21, 2013 | 02:02 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I've had to run 7.25" pushrods in a few engines. Just depends on the combo.
Old Jan 21, 2013 | 12:07 PM
SSmikeSS's Avatar
Originally Posted by Atomic
Have your heads been milled any?
I use 7.3" pushrods on my 402 since my heads were milled some, and there was a slight mill on the deck surface. Trust your measurements.
If I remember correctly, the heads were milled originally to achieve my stock compression(10.1:1). I figured that would just make them the same thickness as my stock 317's. That could be a wrong assumption right there. Also they were just milled .009" to make sure they were straight and true.
[QUOTE=AKlowriderZ71;5054759]I've had to run 7.25" pushrods in a few engines. Just depends on the combo.
What was the reason for making the PR had to be shorter? Milled heads?
Old Jan 21, 2013 | 01:12 PM
TXsilverado's Avatar
head milling, base circle, block decking, rockers, and lifter model can all affect pushrod length. trust your measurement IMO. I may have a set of 7.250 pushrods laying around.
Pimpinpete
43
Dec 22, 2017 08:13 AM
drummer0415
11
Oct 24, 2015 08:16 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
