Nitrous Cam!!
Old May 6, 2006 | 06:57 PM
99LoweredSierra's Avatar
Default Nitrous Cam!!
What is a good comp cam for nitrous and some headwork?
Old May 6, 2006 | 07:06 PM
ONLYA4.8L's Avatar
For what? I heard Thunders TR224 112 lsa would be a good 1...
Old May 6, 2006 | 07:18 PM
5.3L sorry
Old May 6, 2006 | 07:37 PM
ONLYA4.8L's Avatar
Tr224 112LSA or MTI C1 cam with a 3k or 3500 stall.. Just from what I have seen...
Old May 6, 2006 | 07:49 PM
what about a Comp Cam?
Old May 7, 2006 | 12:45 AM
comp 224 i guess, why are you so set on comp?
Old May 7, 2006 | 09:57 AM
Rhino79's Avatar
9 Second Club
NItrous will like split-duration cams with higher LSA as compared to the 224. I would go with this cam from thunder (Comp grinds their cams I believe) 99-TR224/227-114and it is a 224/227 with .563/.569 on a 114 LSA. That cam would be awesome with nitrous.
Old May 7, 2006 | 01:16 PM
Sport Side's Avatar
It's not that N2O cams require wide LSAs... A wide LSA is a by-product of the longer exhaust duration needed to fully empty the cylinder, while maintaining the same or similar amount of overlap.
This will make it easier to understand.
Lets pretend like this would be a perfect all motor camshaft:
226/226 on a 112LSA
It has 2* of overlap
Now, you'll be spraying a 300 shot so, were going to add a good bit to the exhaust lobe... Remember, overlap is combination of the LSA and the amount of duration... Never one by itself.
So, if we add more exhaust duration for the N2O, the overlap is going to increase.... but, we don't want it to. So then, what do we do!!? Widen the LSA.
226/234 on a 114LSA
But truthfully, you need to think about if you are making a nitrous dedicated motor or not. If your still going to be doing all-motor sprints, why sacrifice your all motor performance and streetability for that occasional hit of N2O.... Think about this... If you go faster all-motor, you need less nitrous to accomplish the same ET. Also, if you want a quicker ET, how hard is it to put a larger jet in? Plus, there are ways to get more 'power' from an all-motor cam while spraying. OPEN UP THE EXHAUST.
Old May 7, 2006 | 08:26 PM
125 would prolly be the most i shoot so what would be best for that??
Old May 7, 2006 | 10:21 PM
if you are going to spray all day and night everytime you race get a split duration but if you street alot and just have the occasional shot of nos then go for a 224/224 and spray the biggest shot that you would want...
