New timing chain loose-why???
Old Apr 16, 2006 | 07:14 PM
Default New timing chain loose-why???
Hey guys,
I just installed the new LS2 timing chain as instructed by peeps on here. I noticed the cheain is much stronger looking then the original that it replaced. My problem now is why in the heck is it so damn loose. It's worse than the original that had 186,000 miles on it. The engine is stock completely, never touched before this. It is a 99 5.3, it also had 3 exhaust bolts sheared of in the heads from being over tightened from the factory. Now that's a bunch of BS! I didn't plan on replacing the gears since they are hardened but I have a top gear from my TA that only has 56,000 miles on it. I'm going to install it tommorow and see if it helps but I wanted to see if anyone on here might have any ideas.
Scott
Old Apr 16, 2006 | 08:16 PM
goshawk23's Avatar
Truck addict
i really don't know why it's looser. i have the same chain but am waiting on getting a 6l before i do the install. i hope someone else can chime in and provide some clues.
Old Apr 16, 2006 | 08:46 PM
99Silver6.0's Avatar
Wierd deal there. When I put the LS2 chain in my 6 it was alot tighter than the stocker was. Maybe your gears are worn down a bit.
Old Apr 17, 2006 | 04:26 AM
Gear wear is a possibility but I never thought this much. I will try the old one from the TA. If that doesn't do it does anyone know what the part numbers are for just the gears? Thanks for the reply's guys.
Wolfee
5.3Okasai
Mar 9, 2022 01:07 PM
03chevytruck
Nov 7, 2016 04:43 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
