New motor is in
Old Feb 17, 2013 | 01:39 PM
  #21
2K Silvy's Avatar
Originally Posted by hsiriyob
Its more i dont get how injectors cause a 50 horse power difference. I get the general rule more air plus more fuel= more power. It looks like the truck injectors max out at 325-350. this explains the stutering at wot, but i cant see 50 horse in an injector swap. The only sensors that were not changed were the o2's. Ill keep digging!
Its going to be the injectors. The more air the more fuel. The injectors can only physically pump out so much gas so what happens is your engine will keep sucking in more and more air but the gas won't be there to get you to the target air:fuel ratio. Running lean could do some damage, it does run a lot hotter.
I saw listen to these guys, they know what they are talking about. That is most likely the only thing wrong.
Old Feb 17, 2013 | 01:42 PM
  #22
quicksilverado's Avatar
Your engine can be capable of making 600 hp, but if the injectors are not up to the task the power will not be there.
Old Feb 17, 2013 | 02:16 PM
  #23
hsiriyob's Avatar
makes sense. Im actually a little relieved. Ill order my intake and injectors from texas speed tomorrow and keep yall posted.
Old Feb 17, 2013 | 02:22 PM
  #24
Mangled03gmc's Avatar
Baltimore Whore
Save some money and just do a TBSS intake..
Old Feb 17, 2013 | 02:25 PM
  #25
03sierraslt's Avatar
You need to find out what your AFR was in the above dyno chart before you theorize. If you are out of fuel then you are out of fuel and need to address it before you pop it from being lean. A 228r cam in a LS1 should peak higher then 6k.
Old Feb 17, 2013 | 02:34 PM
  #26
1FastBrick's Avatar
Custm2500's Rude Friend
whats the risk of leaning out? do i need to go easy on her till i figure it out?
Ill see if i can get access to the data, but im blind right now. my gut tells me tune and fuel should get me right. Its just my first build and im over my head. I would like someone to take a look at the tune in houston if its at all possible.
Leaning out can spell disaster for your engine. Doesn't matter how built it is you can destroy the pistons.
When you lean out the mixture you create excessive heat in the cylinders. This will prematurely detonate the fuel in the cylinder. This will cause knocking. This can all cause internal engine damage if its severe enough.
That is why the engine is not making quite as much power as you expect.
More fuel will help keep the cylinder cooler allowing you to run a little more timing. when running properly this will allow you to make more power.
Why do you think the Drag Racers are always tuning up there engine's between runs??? A difference in 10 Degrees in the out side temperature can slow the car down or speed the car up. By adjusting the Fuel and timing allows them to make the most power for the conditions present just before they run.
Old Feb 17, 2013 | 02:42 PM
  #27
Baltimore Whore
Exactly
Old Feb 17, 2013 | 03:45 PM
  #28
hsiriyob's Avatar
only reason im going fast is to fog it down the road. You sell that bed yet cause i want it bad!
Old Feb 17, 2013 | 03:49 PM
  #29
Baltimore Whore
Many issues with leaks with that FAST intake. Yup still have the bed, all covered up for the winter. Contemplating just putting it on the truck.. Make a road trip LOL come get it.. It needs a home
Old Feb 17, 2013 | 03:52 PM
  #30
hsiriyob's Avatar
No knocking as i can tell. I will go easy on her till i get new injectors. I really love the instant feedback the forums provide! Ive been stressing over this build, but atleast now I have some answers. thanks for the help.
