new found power for the 5.3
Old May 14, 2014 | 10:26 AM
chvy=power's Avatar
so your gonna pull the the 5.3 out and do a rebuild?
Old May 14, 2014 | 11:51 AM
TXsilverado's Avatar
buy a junkyard 6.0 before rebuilding that 5.3. cheaper and more power.
Old May 15, 2014 | 12:56 PM
69Camaro427's Avatar
X2 or buy a lower millage 5.3L stick a isky triple 12 cam in it with new
timing chain/gears
possibly an oil pump
I would replace the lifters
Ls9 gaskets
Head studs
Leave the heads alone stock 9.5 compression is great for boost
This set up ^ is proven time and time again for turbo aps, and that cam will work nicely n/a till you get around to boosting the truck.
Don't get headers if you plan to boost, b/c you will have to turn around and by special turbo manifolds/headers
You will eventually need to upgrade the fuel system to the power out put you want, but the stock fuel system is plenty for a n/a cam 5.3L
Old Jun 15, 2014 | 12:40 PM
gonzo 6.2's Avatar
6.0 $200 used cam trailblazer converter.....this if you are on a budget
GMCtrk
38
Aug 9, 2015 08:50 PM
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
grantpo
Jul 15, 2015 12:21 PM
1320Chicken
Jul 14, 2015 10:58 PM
