New to the fast truck scene need help picking a cam
Old Oct 16, 2013 | 03:09 PM
Txblue's Avatar
Oh ok that sounds right.
Old Oct 16, 2013 | 05:20 PM
69Camaro427's Avatar
Originally Posted by Txblue
I put the SDPC HT-1 cam (214/218 55x56x lift on 111lsa)in my daily driver. Stock stall and it sounds mean for a smaller cam. No loss of low end and huge improvement over the entire rpm range.
http://m.youtube.com/watch?v=ssnieM5PGm8
http://m.youtube.com/watch?v=BJdY63R87tM
Speedo vid with stock stall
http://m.youtube.com/watch?v=6cOV-IIJnpE
That is the one I ment not 214/220. Your cam is bad a man for a tiny cam
Personally I hate stalls for a dd, can't stand the rpms up around 2-3K trying to get to 30-40mph. Pisses me off actually haha, but for a weekend toy stick a 4000+ stall
Old Oct 16, 2013 | 05:23 PM
Originally Posted by MPFD
The first cam I did in my 5.3 was a 212/218 .520 .522 and it killed my low end power. It went from smoking the tires with the stock cam to not being able to even roll them over once.
I agree, I think with a stock stall the most low low low end tq is going to be the stock cam.
Old Oct 16, 2013 | 05:24 PM
Txblue's Avatar
Thanks. I'm real happy with it.
Old Oct 16, 2013 | 10:30 PM
1Bear's Avatar
Not that it would be mine or most peoples 1st selection for a true performance cam, especially for the amount of work that goes into installing one, but GM’s 5.3L High Output Camshaft Kit (88958775), which is supposed to add 25hp according to GM's literature would be a very mild upgrade that wouldn’t upset idle quality or mileage and should still be very torque friendly. Its spec’s are as follows: Camshaft Duration @ 0.050”: 203° intake / 212° exhaust, Valve Lift (in): 0.525” intake / 0.526” exhaust, LSA 117.5°
It has spec’s that are very similar to the stock LS3 cam, which is used several of the crate 6.2’s putting out decent power. The LS3 cam as used in the crate engine is listed under part number 12603844 “450hp LSX376-B8 Crate Engine (F) Camshaft” and is a good deal less expensive than the HO cam for the 5.3L though its exact specs may not be as quite favorable to the smaller cubic inch cathedral port headed engine. Its spec’s are as follows: Camshaft Duration @ 0.050”: 204° intake / 211° exhaust, Valve Lift (in): 0.551” intake / 0.522” exhaust, LSA 117.5°
At a minimum, for me, I would most likely look towards something such as the Vinci – 280 “Street Torker” camshaft. Its specs are as follows: Camshaft Duration @ 0.050”: 212° intake / 222° exhaust, Valve Lift (in): 0.551” intake / 0.551” exhaust, LSA 115° It has a description of: Good Fuel Economy, Street Performance, Power Range 1700 to 6000, Tuning Required, Choppy Idle
Any of the above camshafts should work just fine on the stock convertor, but would still benefit from a slight stall, especially the Vinci cam, where something in the 2800rpm range should make it a blast to drive.
Old Oct 17, 2013 | 02:33 AM
Jake75's Avatar
i put a 222/224 112 lsa in my truck with stock stall with no problem but when i put my 3600 stall it woke it up and was a whole new truck off the line. of course now i got tired of it and had pat g spec me a bigger cam for my setup
Old Oct 18, 2013 | 12:09 PM
Blackpanther99's Avatar
I have heard TSP's 224/224r cams are great with stock stalls.
Old Oct 18, 2013 | 12:42 PM
Txblue's Avatar
I wouldn't run a 224r on a stock stall for a daily.
Old Oct 24, 2013 | 04:52 PM
Malikkloftis's Avatar
Thanks everyone for y'all help! I'm just wanting to hit between 400-500 horsepower
Old Oct 24, 2013 | 06:22 PM
Why is that? Not being a douche or anything just asking for a answer.
wrb002
Aug 31, 2015 12:00 PM
steves86ta
Jul 28, 2015 10:21 AM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
Aboss
Jul 9, 2015 10:28 AM
