5.3L pushrod help
Old Oct 23, 2013 | 04:18 PM
BwalterChevrolet's Avatar
Default 5.3L pushrod help
building a 5.3l for a 1500 3door
cam XR259Hr-12 duration: 206,212 lift: 515,522
comp cam hydraulic roller lifters
ls6 springs
wondering if anybody has used the same set up and what kinda pushrods did you use
Brian
Old Oct 23, 2013 | 04:29 PM
gamble686's Avatar
You will want hardened pushrods for longevity and brand has little importance however you will want to measure even it I would guess 7.4 length.
Old Oct 24, 2013 | 06:23 PM
Blackpanther99's Avatar
Yup^ 7.4 will do.
Old Oct 25, 2013 | 01:00 AM
69Camaro427's Avatar
x3 as long as the heads are NOT milled and stock height gaskets 0.051 or 0.053 are used 7.4 will work fine.
I do believe the stock pushrods are 7.38 but everybody buys and uses the 7.4s with no issues
Old Oct 25, 2013 | 06:54 AM
Ryan Mills's Avatar
I ran a mild lunati voodoo cam in my 5.3 s-10 with double valve springs and stock pushrods for about 6 months before I sold it. I do believe that the factory pushrods were a touch short, and do believe that the 7.4 would have quieted everything down, but I never got around to it. It worked, just sounded like a sewing machine when running above 2000 rpm.
SS94S10
Jan 3, 2019 01:57 PM
JordanH
Nov 6, 2015 07:42 PM
old motorhead
Sep 29, 2015 08:22 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
