new engine low oil pressure
Old Jun 18, 2012 | 07:42 PM
  #21
03sierraslt's Avatar
Subscribed for outcome.
Old Jun 19, 2012 | 10:13 AM
  #22
bad cutt's Avatar
I shimmed the spring in the pump and now have 35 psi at idle and it goes up according to rpm. wierd since this was a new gm pump. I am now also running rotella, which i had planned on running after breakin anyhow. all is good for now.
Old Jun 19, 2012 | 10:41 AM
  #23
nonnieselman's Avatar
15w40?
Old Jun 19, 2012 | 11:45 AM
  #24
Ferocity02's Avatar
Did you do the shim and oil at the same time?
Did you compare the new pump to and older one, or the spring in the pump to see if there was a difference?
Old Jun 19, 2012 | 01:59 PM
  #25
Stampede4ever's Avatar
What is this Barbell you speek of? Never heard of it.
Thanks.
Old Jun 19, 2012 | 02:25 PM
  #26
Thanks.
Smallest part in the world that will turn your day upside down. Especially if the motor is already installed with tranny in there.
GM Oil Restrictor
Old Jun 19, 2012 | 07:20 PM
  #27
Ferocity02's Avatar
Thanks.
It goes into the oil galley at the back of the block. If it's not in there the oil will go through the galley past the filter and right back into the pan.
Old Jun 19, 2012 | 08:43 PM
  #28
bad cutt's Avatar
I shimmed the pump and gained 15 psi and the 15 40 rotella gave me another 10
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Sep 7, 2015 05:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
jrplz
Jul 9, 2015 12:07 AM
Mzay
Jul 6, 2015 11:03 PM
