New Cam!!!
I just got a cam... Finally!!! Its a 224/224 .580/.580 114Lsa... Now need to know what else I need.. I have dual Valve spring already... I know I need.. New push rods and seals.. Can I use stock retainers or get new ones? Also what else can I add to get more power outta this cam? Heads? LT's?
stock retainers are fine for your set-up, you'll need a new crank bolt though and a new water pump gasket.
cam and LTs will obviously compliment the cam. you having you PCM tuned accordingly right? if not it's not going to run well if it starts.
I have the seats.. Just was wondering about retainers... I know Ima go with long tubes.. Think ima go with pacesetters.. As of heads... I wanna get my stock heads worked.. Or should I look at LS1 or 6.0L heads and gettin them ported?.. Im going to have 2500 bucks to spend for LT's and heads...
good luck, i think with the ls1 or 6.0 heads its gonna mess with your compression ratios and stuff alot so you might have to get them worked on, if i was you i would take your heads somewhere and get them worked up and all based on the cam you have. your retainers shoudl workfine
Good luck with it.
