New 370 pics
Old Feb 26, 2009 | 10:54 PM
  #31
dlt76028's Avatar
interested in seeing some new times after its broken in.
Old Feb 28, 2009 | 02:34 AM
  #32
454SuperSport's Avatar
damn good work man!!! nice to see somebody choose good parts and take the time to put it together the RIGHT way. kudos to you
Old Mar 1, 2009 | 06:54 PM
  #33
stock48's Avatar
9 Second Truck Club
Thanks
Old Mar 1, 2009 | 07:22 PM
  #34
how about alittle more info on your setup? like what trans/converter and any driveline or suspension mods? what meth kit you running? i'm very interested in this build, looking to do something similar in the near future
Old Mar 1, 2009 | 08:32 PM
  #35
Very nice!!! I would really like to do something as well sometime.
Old Mar 19, 2009 | 01:43 AM
  #36
stock48's Avatar
9 Second Truck Club
-Junkyard 80E with trans go HD-2, pro yank 3400(now precision 10.5'' 5500RPM Lol)
-Autotrack Tcase with 3/4 ton input hub, custom drivelines
-Stock suspention, lift blocks removed, 3'' shackle, T bars down all the way, straps on front end at track
-Snow perf 220psi meth kit
-3.73 gears, stock G80
Old Mar 19, 2009 | 01:46 AM
  #37
GMCtrk's Avatar
How did you fit a 3" shackle? Even the 2" one goes all the way up to the underside of the bed.
Old Mar 19, 2009 | 01:49 AM
  #38
stock48's Avatar
9 Second Truck Club
ah, I didn't know you gernaded the old motor. I had one head for my new motor that had seat damage on almost every seat. But rather then waist the time replacing nearly half the seats, I just replaced it. I have a set of heads from a BBQ special that got so hot, the seats actually droped out of it.... There only good for dummy mock up or if some one wanted to use them for an in car Valve clearance head with that tool from ISKY or the one from Lindy
Do you have any post about your turbo set up???
Somewhere but it was a year or so ago.
-STD Trick kit, with Turbonetics T76 W/C BB, 3'' Dp, and nelson I/C
-Stock truck intake, TB, MAFS, 60LB injectors, stock FPR, and rails
Old Mar 19, 2009 | 01:53 AM
  #39
stock48's Avatar
9 Second Truck Club
Maybe it was a 2'' for some reason I thought it was a 3. It does almost hit the bed.
Old Mar 19, 2009 | 02:20 AM
  #40
RickLowpez's Avatar
r u going 2 run here at famoso raceway? if so when? really want to check out ur set up.by the way good job
