needs some help guys
Old Sep 18, 2008 | 04:26 PM
slowlsx's Avatar
Default needs some help guys
I have an 01 silverado 5.3 with exhaust,throttle body spacer,programmer, and a k&n. I went to the track along time ago and it ran 14.1 , I'm looking to get in the 12's on motor. Could anyone recommend a set up. I was think heads and cam and at the most 3200 converter and a custom tune of course.Im also looking for a radical cam.mainly I waned a recomendation on a cam because there is so many I just wanted to see if someone has a set-up that I'm looking for.
Thanks
-josh
Old Sep 20, 2008 | 01:16 PM
slowlsx's Avatar
anybody??
Old Sep 20, 2008 | 06:33 PM
terravast4's Avatar
Radix, cam, heads, converter, long tubes, 60# injectors, meth, a good tune and some slicks. Might as well throw in a new trans and some cal-tracs so you can put it all down.
Old Sep 20, 2008 | 06:38 PM
outlawz2004's Avatar
Thanks
-josh
Hell, thats good for the mods you have. Ext cab or reg cab.
Old Sep 20, 2008 | 07:56 PM
dlt76028's Avatar
thats what i was thinking? 14.1 with a programer and exhaust is pretty damn good.
Old Sep 20, 2008 | 08:01 PM
must be the spacer.
Old Sep 20, 2008 | 08:15 PM
slowlsx's Avatar
it's a reg cab andi had ran that time along time ago otherwise I would post the slip. The truck feels realy strong and was kinda looking to run in the 12's n/a and have a little 100 shot on the side.i don't see why 12's isn't possible with heads/cam/converter. Superchevy.com put heads and cam on a 5.3 with boltons and lt's and made 460hp!!! I didn't evan know that was possible.
Old Sep 20, 2008 | 08:21 PM
95 bright teal's Avatar
there are a few guys on here that dipped into the twelves NA, its possible.
Check out bluecajuns truck he has what your looking for
https://www.performancetrucks.net/fo...er.php?u=32778
Old Sep 20, 2008 | 08:32 PM
slowlsx's Avatar
Yea that guy has a sick *** truck. I just notice that alot of people put heads cam and converter but only a few hit 12's? Is it the tune?
Old Sep 20, 2008 | 08:35 PM
You should be able to hit 12s. Also depends on altitude, some of those 13 sec trucks would run lower times closer to sea level.
