Need some help with a couple of engine parts...
Old Dec 27, 2008 | 12:20 AM
usabodyguard's Avatar
Blown 427 LSX
Question Need some help with a couple of engine parts...
I need some help - links would be great and pics would be awesome - on the following parts i still need, the engine assembly starts next week. I prefer NEW parts, if you personally have a part listed you want to sell that is still new, PM me.
Need the following:
Double roller timing chain LS2 style
Oil pan - want something better than stock (truck style)
Quality billet idler pulleys (I will be running at least the ATI 10 rib set up, unless i can get a cog set up for the TVS 2300)
Plug wires - top of the line
160* TStat
90MM TB Harness
Thanks in advance...
I will update list as I get these items... I may need a few more things.
Old Dec 27, 2008 | 12:46 AM
moregrip's Avatar
what a rush!
by a better oil pan than stock what do you mean? better looking?
there is only one company that makes truck style 10rib idlers worth a hoot that I know of,
Old Dec 27, 2008 | 12:53 AM
chevyguy7802's Avatar
Moroso makes some sweet fabricated aluminum oil pans I think one is a 7 quart....I dont know if they would fit tho...
Old Dec 27, 2008 | 01:34 AM
Blown 427 LSX
Yea I meant better looking... sorry
I will check out Reichard Racing... thanks
Old Dec 27, 2008 | 11:46 AM
moregrip's Avatar
what a rush!
Canton makes the nicest LSx Oil Pan that I've seen
Old Dec 27, 2008 | 11:53 AM
moregrip's Avatar
what a rush!
I like Taylor wires, but there are many top quality plug wires available.
For the 90mm TB harness you have 2 choices, TAC module/Speartech harnes, or Dr X harness. Best looking setup is to get the setup you want and re-wire it for looks.
I'd go with an Evans waterless coolant system conventional, Meziere if going electric
Please tell me you are going with a billet steel flexplate?
Old Dec 27, 2008 | 12:17 PM
Wilde Racing's Avatar
How do I change this text
I have hear a lot of bad things about evans waterless coolant.. I WAS going to use it until I talked to a few people that had tried it already..
Old Dec 27, 2008 | 12:18 PM
BlownChevy's Avatar
blownerator
25 Year Member
Need the following:
160* TStat
90MM TB Harness
The stock oil pan is MORE than fine for your application. Save your money and just polish the stock one
There is a reason the stock plug wires cost more than the aftermarket garbage
The only 90mm TB harness I would use is made by w w w .torquerush . com
Old Dec 27, 2008 | 12:28 PM
moregrip's Avatar
what a rush!
what did you hear to the negative?
Old Dec 27, 2008 | 12:30 PM
moregrip's Avatar
what a rush!
what are the differences in plug wires that make stock better?
