need some help asap
Old Aug 3, 2012 | 09:50 PM
03 silverado's Avatar
Default need some help asap
well i started hearing a ticking noise coming from the right side of my engine an pulled the valve cover off today, i think its my rockers being loose cuz i can move them side to side roughly 16th inch, they have 274,000 miles on them. could this be my problem? i didnt have a chance to check the other side but theres no noise on the left side. need some help quick because im going on a 850 mile trip this weekend. mods r in the sig, thanks
Old Aug 3, 2012 | 09:57 PM
Fastcount03's Avatar
Did you install new lifters with the cam?
Old Aug 3, 2012 | 10:01 PM
nope only springs an pushrods, got about 6,000 miles on them an the cam
Old Aug 3, 2012 | 11:28 PM
Atomic's Avatar
I have a gauge for that
Are you sure the spring isnt broken? Make sure the rocker bolt is still torqued...
Old Aug 3, 2012 | 11:31 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Side to side is actually normal. It's up and down you need to worry about. Up and down is were the Pre-load on the lifter is.
Old Aug 4, 2012 | 06:12 AM
ok ill the rockers torque is good an the springs are still good to so thanks
Pimpinpete
43
Dec 22, 2017 08:13 AM
GM1697
Sep 28, 2015 08:28 PM
MOBBN
Sep 22, 2015 08:07 PM
