Need some help
Old Jul 25, 2010 | 06:13 AM
rocky2007's Avatar
Cool Need some help
I have an 07 silverado classic,I just bought a camshaft. Is's a TSP 232/234 598/598 1800-6300 rpm.I know I will need to retune my truck and I am thinking of running a 2500 stall, but I don't know if thats big enough.I have some pacesetter lt's,tb spacer, and a cold air kit on the way. Does anyone know of anything else I might need to make this cam live in a 4.8 liter. Also what gears should I be running out back?, oh it's a crew cab. The cam is probably over kill I know .
Old Jul 25, 2010 | 06:33 AM
Wheatley's Avatar
Truck Sponsor
That cam in a 4.8 in a crewcab? If you don't mind me asking,why so big?
Either way,if you run that cam I would say you will need atleast a 3600-3800 stall converter.A 2500 stall converter won't be enough for that cam in a 4.8 in a crewcab.
Old Jul 25, 2010 | 06:54 AM
Suddog's Avatar
Holy BIG cam Batman!
You will need different valve springs and hardened pushrods for sure. Did you get the TSP cam package?
Old Jul 25, 2010 | 07:17 AM
2007chevy5.3l's Avatar
Damnnn thats a big *** cam
Old Jul 25, 2010 | 09:01 AM
rocky2007's Avatar
Ok guys I got lucky an the order didn't go through, for once the bank helped me from making a bad impulse buy.I will still get the tsp package ,but only alot smaller. I have to call the bank to do big spending cuz I am currently depolyed to Afghanistan.
Old Jul 25, 2010 | 09:56 AM
u need a 21x-220 cam......i had he tr220 in my 4.8 and it screamed. but i had a 3200 stall also
Old Jul 25, 2010 | 11:24 AM
rocky2007's Avatar
Does anyone know when they went from a 3 bolt pattern to a 1 bolt. Or can I just use the 1 bolt cam sprocket
Old Jul 25, 2010 | 12:26 PM
white1's Avatar
'07 in the Gen IV. The '07 classic should still have the 3 bolt cam.
Also, the GEN IV has the cam position sensor in the front, where the GEN III has it in the rear. Im not 100% sure, but I think most of the one bolt cams are going to be GEN IV (cam position in front)
