Need some guidance
Old Jun 23, 2021 | 11:42 AM
Jeronimo103's Avatar
Registered User
Default Need some guidance
I have a 6.0 lq4 I'm putting in a truck. Not a race car just a daily driver and pulls the race car. Intended on using factory rotating assembly with new bearings and rings with a btr stage 2 truck cam. I had the block honed and new cam bearings put in and when I got it back there was still grooves in the cylinders. Long story short its gotta be bored.... I'm guessing. 010 to .030 over. What's the most economical way to do the rotating assembly since I now need over size pistons and assume it's going to need balanced. Buy a complete aftermarket rotating assembly or certain piston/rod combo with stock crank? Sorry for the long post any help is appreciated.
Old Jun 23, 2021 | 11:54 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Just do a stock crank and then rods and pistons. I would go .30 over to make it a 370.
Old Jun 23, 2021 | 12:06 PM
Registered User
any suggestions on a set of rods and pistons?
Old Jun 23, 2021 | 07:57 PM
arthursc2's Avatar
Honestly, for quick turn around and low cost, get a set of .03 pistons and rings off RockAuto, verify the gaps and run it
Tradeordye3000
14
Oct 15, 2017 08:13 AM
Furdkiller
Dec 1, 2016 12:47 AM
BLWNLT1_T/A
May 20, 2016 02:34 PM
beastmode
Mar 6, 2013 04:12 PM
Michael Halo
Oct 24, 2009 01:13 PM
