Rookie mistakes...4.8 torn down to bare block
Long story short. Tore apart a 4.8 going to get new cam bearings, main bearing, honed and re-ringed. Where I believe I messed up is I didn't label the rod caps nor did I put them back on the same rods I took them off of. Any way to identify them or am I screwed?
Theyre broken rods so they need to go back with their mate...... Close enough wont cut it on those.... You could actually take the cap and match it to the rod by putting them together and of the line between them all but disappers you should be good.... Lessons learned!!! Weve all been there!!!
Thanks for the help guys... Took it all to the machine shop this morning Block vat, new cam bearings, main bearings, rod bearing, turn the crank, and resurface the heads... 700.00 bucks
nova421
Apr 22, 2016 10:35 AM
