need to make more on motor???
Old Feb 16, 2009 | 06:00 PM
05crew's Avatar
Default need to make more on motor???
i had the truck tuned today and it only made 371rwhp. i am out of injectors and am working on getting them asap. the cam is a 228-232 on a 114lsa. the heads are PRC 2.5 and its on a 370ci motor. i was think that it would make around 400 or so. what can i do to make more HP. im going to spray a 200 on it this week but im trying to make 400 on motor and 600+ on gas so i will me around the same ET as the turbo.
thank for the help and INFO
Old Feb 16, 2009 | 06:28 PM
Truckshop's Avatar
any more specs on the heads? what intake? what rpm did you pull to?
Old Feb 16, 2009 | 06:51 PM
05crew's Avatar
this is what website say about the heads. flow 312 at .600,
# Stainless Steel 2.02"/1.575" Valves
# PRC Double Spring Kit Complete With
Springs, Titanium Retainers, Seats, & Seals
dont know what RPM he pulled to, and its a stock truck intake, i was told that LS6 intake would take away form my bottom end. i was better off staying with the truck intake with the longer runners.
but what do i know. this is all coming form Ryan at RPM so i take him word or word.
Old Feb 16, 2009 | 07:04 PM
Truckshop's Avatar
that cam is gonna take away from your bottom end more than a truck intake. you probably need to to 6800 or so to get peak power from that cam. the truck intake is gonna hold you back past 6000 or so.
Old Feb 16, 2009 | 07:09 PM
Truckshop's Avatar
i also saw your other post. if these are 5.3 heads i am gonna say that the runners are too small for good top end power. should have awesome throttle response and low end torque though. i am gonna say you either need to step down in cam duration or get a better set of heads.
Old Feb 16, 2009 | 07:15 PM
05crew's Avatar
it feel good down low as it is. but i would love to get a little more out of it.
Old Feb 16, 2009 | 07:16 PM
05crew's Avatar
thanks for the help ill run it by him and see what he thinks.
Old Feb 16, 2009 | 07:24 PM
ZR1 DREAMING's Avatar
I think your heads and cam are too small for your goals.
If your budget permits step up to some AFR 225s or the TFS LS2 heads, then get a healthy cam for it. Then you need to add a FAST90/92. After that you'll have pretty much the same combo I do
Old Feb 16, 2009 | 07:29 PM
kbracing96's Avatar
Just do the turbo and forget about it, no bottles to fill.
Old Feb 16, 2009 | 07:44 PM
05crew's Avatar
i was trying not to go with that big cam so i could still have a lot of low end and it would not be such a pig down low,
KB, ill give you the heads and the nitrous kit and some cash for the turbo.HAHAHA
