need help with cam for l92's
Old Aug 15, 2010 | 09:52 PM
iamkeniff's Avatar
the +2 or +3 is already ground into the cam, so there is no need to "advance" the cam. just put it dot to dot and have fun
Old Aug 15, 2010 | 10:27 PM
zippy's Avatar
With the truck intake 8 degrees of split is enough. I'd recomend something like the Comp Cams 281LR HR13 (54-459-11). The spec's on it are 231/239 .617/.624 on a 113. The off the shelf grind is with a +4 advance with along with the 113LSA will help to keep the part throttle low rpm drivability reasonable. It would be easy to go bigger with that much stall, but I wouldn't recomend bigger since you want to keep the drivability in check.
Old Aug 22, 2010 | 06:35 PM
Fastcount03's Avatar
So you guys think a 239/247 623/623 114+2 would be to much of a cam in a L92 headed 408?? I have heard both ways on the cam and am now wondering. Any of you have a link to some info to show either way?
OHsixLS3
Dec 27, 2016 09:30 AM
Silveradorst07
Dec 31, 2015 12:04 AM
USMCvet0311
Sep 30, 2015 10:34 AM
subeone
Aug 19, 2015 07:44 AM
USMCvet0311
Jul 29, 2015 01:28 PM
