need ADVICE FROM EXPERIENCE NOT HEAR SAY
Old Jun 1, 2016 | 11:29 AM
tim wellington's Avatar
Default need ADVICE FROM EXPERIENCE NOT HEAR SAY
BLOCK has spent number 3 cam bearing twice .?? does any make over size cam bearing (to have bearing whole bored out )or roller bearing for gen 3 block or do i need to go with another block ,getting frustrated
Old Jun 1, 2016 | 11:14 PM
Wolftrk99's Avatar
Was the cam journal in the block bored out last time it spun?? The 1and 5 cam journals are damn near .040 larger than the #3 journal, and the #2 and #4 joirnals are about .020 larger than #3.... So theoretically the #3 journal can be bored out to the same diameter as 2/4 or all taken out to same as 1/5...
Old Jun 2, 2016 | 01:28 AM
Blown06's Avatar
8 Second Truck Club
Really just depends. Compare the cost of just replacing the block and having it machined to toss all your existing parts in VS. having the cam bearing bores fixed and then having to buy 5 sets of bearings to get all the ones you need (unless you can find someone to just make you a set).
I'd forget the roller bearing idea.
Old Jun 2, 2016 | 08:39 AM
Default cam bearing
thanks to both .i thought only 1 and 5 was larger and other 3 where the same .block is an 05 . i have over 1000 dollars in the block .i have 2 other bare blocks 02 models (i would have to change head bolts plus honing and boring all over again) .does any body have cam bore specs or know where i can find them .conflicting info 2000-2004 long and short head bolt models vs 2005-2006 short bolt beefier rod engine
Old Jun 2, 2016 | 09:43 AM
Wolftrk99's Avatar
Canshaft bore 1 and 5 dianeter-2.347-2.349
2/4 2.327-2.329
3- 2.307-2.309
Straight from si for an 05 lq9
Old Jun 2, 2016 | 09:48 AM
Default thanks for all your help
2/4 2.327-2.329
3- 2.307-2.309
is it the same for 2000-20004? what does si stand for, all the machine around here are lost on l/s engines
Old Jun 2, 2016 | 10:20 AM
madmann26's Avatar
You can get a prepped block from Summit pretty cheap.
Summit Racing® Iron LS Engine Blocks SUM-4853L - Free Shipping on Orders Over $99 at Summit Racing
Old Jun 2, 2016 | 10:23 AM
Wolftrk99's Avatar
2002 lq4 2.307-2.309 for #3
2/4 -2.317-2-319
1-5 are 2.327-2.329
Si is gm service information
Old Jun 2, 2016 | 10:43 AM
Default block
Originally Posted by madmann26
those are 4./8/5.3 no 6.0
Old Jun 2, 2016 | 10:59 AM
madmann26's Avatar
oops.
