need ADVICE FROM EXPERIENCE NOT HEAR SAY
BLOCK has spent number 3 cam bearing twice .?? does any make over size cam bearing (to have bearing whole bored out )or roller bearing for gen 3 block or do i need to go with another block ,getting frustrated
Was the cam journal in the block bored out last time it spun?? The 1and 5 cam journals are damn near .040 larger than the #3 journal, and the #2 and #4 joirnals are about .020 larger than #3.... So theoretically the #3 journal can be bored out to the same diameter as 2/4 or all taken out to same as 1/5...
Really just depends. Compare the cost of just replacing the block and having it machined to toss all your existing parts in VS. having the cam bearing bores fixed and then having to buy 5 sets of bearings to get all the ones you need (unless you can find someone to just make you a set).
I'd forget the roller bearing idea.
You can get a prepped block from Summit pretty cheap.
Summit Racing® Iron LS Engine Blocks SUM-4853L - Free Shipping on Orders Over $99 at Summit Racing
