Nasty Camshaft
Old Jul 20, 2011 | 01:00 PM
  #41
06Sierra2's Avatar
scott, what are the specs on your cam?
Old Jul 20, 2011 | 01:18 PM
  #42
cdub81's Avatar
I believe he has the tsp 228r 228/228dur 588/588 lft
Old Jul 20, 2011 | 01:52 PM
  #43
TORQUE RACING's Avatar
GM performance says this is a drop in cam with no mods required but tuning recomended (no stall, no facny BS, maybe some Z06 springs)
Hot cam specs:218/227 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
112 LSA
So why would one step up be so drasticly wrong for a 5.3, and if i wanted all my power in the bottom end i would buy a big block not a ls small block so im not looking for these cams in the 800-4500 rpm range. The pic show my 35x12.50x22 tires and 22x11 wheels but i recently sold them and removed my 4in of lift. I am now running a 305/50/18 on alum. wheels.
Old Jul 20, 2011 | 01:58 PM
  #44
00ChevyScott's Avatar
Wearin' da big hat
If you knew anything you'd know that the GM hot cam is a piece of ****. But don't listen to what we have to say, none of us have any experience with cammed trucks.
Old Jul 20, 2011 | 02:12 PM
  #45
I reallize that hot cam is a piece thats why im looking for a better solution and the one mentioned earlier was a custom grind from the guy who grinds the bullet cams... he said i could choose i diff lsa to meet my satisfaction. so would a higher lsa make that cam any better?.... 00chevyscott i like the sound of yours what kind of specs and numbers are you running?
Old Jul 20, 2011 | 02:20 PM
  #46
Mangled03gmc's Avatar
Baltimore Whore
A split duration cam will make more tq under the curve, vs a single pattern cam in most case, as it keeps the exhaust side open longer.. Bottom line your truck is big and heavy.. A cam that is donkey dick is going to need a huge converter to get the truck moving, to keep the shift points high to stay in the power band.. a 218-220 cam with a 3k verter will be a nice wake up call with you truck, or step up to a 220-224 cam and add a little more converter.. all in the sake that your truck is heavy.. If ti were a reg cab truck, you had less weight to tote around then a bigger cam would not be as much of a issue..
Old Jul 20, 2011 | 02:21 PM
  #47
https://www.performancetrucks.net/fo...a-cams-484857/
these posts are showing guys running higher durations and same and lower lsa on a 4.8 and loving it? so i am getting confused? Is there that musch weight difference between ex. cab and single cab?
  #48
Baltimore Whore
Cam Basics - Tech Article - Chevy High Performance Magazine
Old Jul 20, 2011 | 02:22 PM
  #49
Baltimore Whore
Look at what trucks there in and what converters they are using, some of them even had advance ground into them..
Old Jul 20, 2011 | 02:23 PM
  #50
Wearin' da big hat
A lot of those guys have a lot lighter trucks than yours, they're proficient with tuning and can tune themselves, they have better supporting mods, and smaller tires.
