N-Motion Timing chain any good?
Old Sep 30, 2012 | 10:46 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
Originally Posted by 1Bear
Just remember that the damper is designed to keep the chain from slapping around as much as what it would otherwise do without a damper and as such is intended to extend the life of the chain. It is not however designed to take the slack out of the chain as a tensioner would do. Unfortunately the factory GM tensioner does not have the best track record and is to commonly found to be in pieces in the oil pan.
The dampner breaking does happen every now and then, I dont see alot of report here on the forums about it, but we do get some calls about it.
Old Oct 1, 2012 | 11:23 AM
Hivelocit's Avatar
Went ahead and ordered the kit from TEA adapter/damper combo. Stayed away from the tensioner too many bad reports on those! Since the chain had some travel damper makes me feel a lot better about chain breakage due to harmonics or high rev. Will post up some pics of the setup since I haven't seen many with the damper/adapter combo as of yet. Crossing fingers I hate clearance issues! Thanks for all the replies!
Old Oct 1, 2012 | 02:10 PM
blueshifty's Avatar
From my experience I'd say the N-Motion sets are just another re-branded JP Performance set. They use rolon chains which are almost as good as IWIS, but much cheaper. I have a JP performance set in my DD and it is just fine.
Old Oct 1, 2012 | 02:20 PM
Atomic's Avatar
I have a gauge for that
Originally Posted by Jake@Texas-Speed
Unfortunately, there are no double rollers that will fit with the melling pumps without some kind of grinding (that we know of anyway). We offer our ported and shimmed LS6 pumps that will fit with most aftermarket sets.
I use a rollermaster double chain with a HO melling pump and didnt have to do any clearancing on the front cover...
Also use one of the block-style dampeners without issues. I have heard of the spring-loaded dampeners having issues though...
5.3Okasai
Mar 9, 2022 01:07 PM
The_W
Oct 28, 2015 09:00 PM
chevyl33
Aug 24, 2015 08:21 AM
Ammadien
Jul 22, 2015 08:50 PM
abey15
Jul 13, 2015 02:20 PM
