My truck suddenly started running roughly today
Old May 11, 2011 | 08:48 PM
MikeGyver's Avatar
Default My truck suddenly started running roughly today
I even kept driving it, to diagnose the miss. It took awhile before it started to make any noise. It's the #1 exhaust valve, by far the easiest to get to on my setup. I am so lucky.
Old May 11, 2011 | 09:15 PM
SincalT/A's Avatar
You gonna changem all?Btw.it sux but,thats the nature eh...
Old May 11, 2011 | 09:22 PM
MikeGyver's Avatar
I'm going to find just the one to put in to make sure everything else is OK. And a seal, too. That's what is blue to the right of the spring. Then I hope to get through the summer and replace all 16.
These are what came in the heads from AFR. I don't know if you call them double springs, or singles with a damper. With 120 lb. seat pressure and 420 lb. open pressure, I'm sure there are a lot to choose from.
Old May 11, 2011 | 09:36 PM
SincalT/A's Avatar
That exhaust valve getten pretty hot here lately?
What kind of total ignition timing you workin with?Ima guess pretty late 8-12 degrees.
You got lucky the valve didnt take a plunge into the cylinder.Springs maybe showing some fatigue from heat and a good amount of harmonics travelin throughem.
Old May 11, 2011 | 09:48 PM
MikeGyver's Avatar
Some of the springs got rusty before I installed the heads, I should have thrown them away right away. Or I should have changed them yesterday.
I didn't even consider that all that noise that finally came might have been the valve hitting the piston. Now I have something else to worry about, thanks.
Old May 11, 2011 | 11:05 PM
SincalT/A's Avatar
I dont think the piston hit the valve.If it did the locks pop out ,and your valve would've deffinately dropped.
Old May 12, 2011 | 06:17 PM
MikeGyver's Avatar
I used a leak down tester, it's hunky-dory. I guess I am lucky, but it would be nice if an indicator popped up in the message center that said "CHANGE VALVE SPRINGS".
Check out how the spring seat's (cup?) walls disintegrated, and the shim that was underneath the seat became cupped.
Old May 12, 2011 | 06:22 PM
TIM Z's Avatar
11 sec. Truck Mod
Your lucky you didnt drop a valve.
Still sucks though, glad ya found it before it got worse.
Old May 12, 2011 | 07:21 PM
03sierraslt's Avatar
Come on Mike, JB weld will take care of that.
Old May 12, 2011 | 08:27 PM
MikeGyver's Avatar
I've been wrenching between downpours. Yay! I probably have to pull the head. Yay!
The valve seal is loose on the guide. I don't understand why I had to pry what was left of the old seal off of the guide, and it is like the new one won't go down far enough to seat, or the guide was somehow damaged by the spring pieces. It's as if the tip of the guide has been distorted and raised, which is keeping the seal from seating. I'm not sure. I can't find different seals, could there be longer seals? They don't look any different on AFR's website.
Picture is AFR #6612 seals.
