mpg with 42# injectors
Old Feb 7, 2012 | 09:04 PM
oakley6575's Avatar
Yes it's lowered 3/5. I took a carb'd 383 gen 1 out of it that was getting 10mpg so when i put fuel injection back in it, I was extremely happy!
Old Feb 8, 2012 | 06:10 PM
ou812sm's Avatar
How bad would a 3200 stall converter from circle d affect the mileage
Old Feb 8, 2012 | 06:58 PM
oakley6575's Avatar
Everyone will tell you it doesn't affect milage but it does. I get great milage on the highway only because its locked most of the time. City driving is significantly less but I don't know an exact number.
Old Feb 8, 2012 | 07:14 PM
AndysC3's Avatar
im only getting 9 city and 14 hwy lol.
Old Feb 8, 2012 | 07:18 PM
GMCtrk's Avatar
I tweaked my tune a bit and now I'm getting 13.9 mpg all city.
Old Feb 8, 2012 | 07:19 PM
jrmchevyman's Avatar
The 278mm converters are still considered pretty tame or mild converters and gas mileage should not suffer as much as you would think. Maybe 1-2mpg less with one of those at worst if your tune is spot on. Now if you get a smaller diameter/ higher performance converter and or quite a bit bigger stalling converter yes you will see more MPG loss lol.
Old Feb 9, 2012 | 12:05 AM
Vortec350ss's Avatar
Thats because of your stall though... and all those 100 MPH runs you put on youtube!
In theory the larger injectors alone shouldnt change gas mileage at all, they just allow for more gas to be fed in higher RPM's when you increase airflow and power.
That being said, its true that its harder to get a big injector to act small than for a small injector to do its job.
Old Feb 9, 2012 | 03:01 AM
AndysC3's Avatar
LOL, and 4.56 gears. I was getting 13.5/16 stock
Old Feb 9, 2012 | 10:13 AM
dmelvin's Avatar
This is correct.
I've got the 278mm Circle D... as long as you keep your foot out of it, it's pretty tame. I lost about 3 MPG in town, but our town is 25mph speed limit, and I'm going about a mile between turns of the key, which doesn't help any either.
I'm getting the same on the highway as I did before, because the converter is locked nearly the entire time.
gaps
Oct 15, 2015 02:53 PM
OHsixLS3
Sep 25, 2015 11:20 AM
rednekferlife101
Sep 14, 2015 05:27 PM
lxcoupe
Sep 2, 2015 12:58 AM
