motor started knocking after WOT pull
Old Dec 1, 2013 | 05:34 AM
  #21
tashspop's Avatar
i agree, but i don't have a cherry picker so that would be more spending needed. with christmas around the corner my choices are be cheap or wait a month to get started.
Old Dec 2, 2013 | 03:54 AM
  #22
Boost-freak's Avatar
i think this sound like a lifter issue to me
you have to pull the head to see what's wrong
Old Dec 2, 2013 | 06:27 AM
  #23
tashspop's Avatar
yes i found several videos with a similar sound that had lifter issues. also reading discussions on ls1 about comp xer profiles makes me wonder too in combination with the springs i found the motor is running on.
Old Dec 8, 2013 | 07:58 AM
  #24
tashspop's Avatar
this is moving so slow with early dark and this crap weather.
ok, i have the pan off now. i found a little metal on the magnet but nothing to speak of in the pan. i was about ready to start pulling the head off today if rain doesn't chase me off, but was wondering if i should pull rod caps off first to check further on my bottom end?
with my frozen hands i couldn't find anything that stood out to me. i only get a little back and forth play along the crank, and no vertical movement. none on the small end/pin either.
Old Dec 14, 2013 | 05:31 PM
  #25
darkirish63's Avatar
Just lost a lifter myself after my Patriot Performance Stage III heads bit the dust and I dropped on a set of AFRs. Had about 150 miles on it and it crapped out. Chewed up a lobe on the cam & scraped up the bearings something fierce. Had to pull the longblock and get 'er refreshed. Got it done last night so I'm on my 500 baby drive. If its a lifter, you would have some metal in the pan - best to pull the heads and see what's going on before it gets worse. Most of all -DON'T run the motor again until you figure out what it is.
Old Dec 17, 2013 | 10:26 AM
  #26
tashspop's Avatar
i have found a squishy(??) lifter, but nothing else. i can press the plunger down easily with my finger. the roller looks to be in great shape so i think my cam will be fine. i still need to pull the drivers side head off to get those lifters out and check them all.
if this is the cause of the issue i guess i can chalk it up as a failed lifter check ball? sure was noisey though for not being completely collapsed.
Old Dec 17, 2013 | 06:30 PM
  #27
Good luck...I hope that's all it is.
Old Dec 27, 2013 | 02:15 PM
  #28
tashspop's Avatar
now that i could get out there with better-ish weather. i found a new problem. this is the rear piston on passenger side (number 8?). but this looks like old damage to me since it has carbon build up and my valve shows now sign of impact.
here it is out of cylinder
Old Dec 27, 2013 | 02:22 PM
  #29
TXsilverado's Avatar
who wants to explain that damage, because i'm drawing a blank here lol.
Old Dec 27, 2013 | 02:36 PM
  #30
AKlowriderZ71's Avatar
11 Second Hall Moniter
Need more pictures of the piston and cylinder head, from multiple angles.
