Motor build pricing
Old Jul 12, 2008 | 07:50 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by gao8302
I paid 1600 for machine work and to have the short block put together. That include hot tank, install main studs, align hone, bore, full balance, all new clevite bearings, gap rings and set up quinch.
That sounds more like what it would cost around here for a half way decent shop to freshen up a block
Old Jul 13, 2008 | 10:05 PM
  #22
7845's Avatar
Banned
the copper is normal for mileage and various cam swaps. as for the scratchs those would concern me. just have cam bearing installed and call it a day
Old Jul 14, 2008 | 03:36 AM
  #23
Spoolin's Avatar
GFYS and STFU
Bore + Stroke =
Old Jul 14, 2008 | 10:50 AM
  #24
beastmode's Avatar
Import Moderator
They said they cant do the cam bearings w/o tearing the bottom end apart... you dont think I should do all the other bearings if it is apart?
Originally Posted by Spoolin
Bore + Stroke =
I am already gonna spend a small fortune on this truck
Old Jul 14, 2008 | 10:57 AM
  #25
1FastBrick's Avatar
Custm2500's Rude Friend
Might as well. Cheap insuranse IMO
Old Jul 14, 2008 | 03:28 PM
  #26
InchUp's Avatar
Cheap insurance indeed. What you spend now on new bearings will be a fraction of what you'd spend later on if one of them went south on you from not replacing it. "You never put a motor back together without new bearings." I learned that when I was 13.
As for the bottom end, there's no reason why a hone and new rings wouldn't work. Have the machine shop check each cylinder bore for any out-of-round culprits and mic all the pistons. If all you need is a small hone and brand new rings then your machine shop bill will be cut in half.
Old Jul 23, 2008 | 03:50 PM
  #27
03sierraslt's Avatar
So what is the latest on this Bill?
Old Jul 23, 2008 | 05:27 PM
  #28
SincalT/A's Avatar
Just a couple pointers that I have learned.
1)Build a repour with the man doing the work and be likeable do not go in and act like you own the place.
2)Get them to semi commit to a price before anything is done.
I know things change but atleast you have a starting point.
3)Have them do a small job for you like polish a crank or valve job and see if you like them first.
4)Know what they are doing to your engine.You don't have to know how as much as you need to know why.
5)Try to name drop with somebody that repeats business in there
basically you need to give them a reason to care about what they are doing for you.
6)Try to use someone that has been referred to you.
7)Get receipts for the work done.
8)Pay with cash if you can you would be surprised at how much that might save you.
Old Jul 23, 2008 | 05:32 PM
  #29
SincalT/A's Avatar
Btw I had an ls1 shortblock recently rebuilt for $900 using some of the pointers in the above post.The work was done by a reputable shop that normally is not cheap.
Old Jul 24, 2008 | 12:50 AM
  #30
Spoolin's Avatar
GFYS and STFU
You needed to contact me before I started my build OMG!! + a million on all those points!!
I got screwed on my first motor install, not likely gonna repeat that mistake again.
