Milling 317's
Old Apr 24, 2009 | 01:08 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Silver-Dollar
What kind of HP/TQ gains are expected with increasing the compression ratio a half a point or even a full point? I know the cam determines powerband, but does a change in compression ratio alter it?
I'm not aware of any rule of thumb numbers (like x points = y hp/tq), but generally, increasing the compression ratio will boost low-end torque and extend the top-end power range
Old Apr 24, 2009 | 01:44 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Higher compression within reason can also increase cruising mileage too
I ran 11.3:1 in my 418 and cruising on the highway it would get around 16 which was close to what the stock 5.3 got, now get it in the city thats where the single digits came on quick
Old Apr 24, 2009 | 05:10 PM
ramdaspadhye's Avatar
I've got an LQ4 and I want to mill my 317's down .040. Will I need a shorter pushrod?
Old Apr 24, 2009 | 07:29 PM
budhayes3's Avatar
PT's Slowest Truck
Yes sir you will, I don't believe that the lifters would like that much pre-load, if they could even make up that much. I'm guessing that a 7.35 pushrod would work, but you really need to get a pushrod length checker and do it right
zblee
Nov 11, 2015 12:41 AM
turbo6c3
Oct 5, 2015 06:11 PM
someotherguy
Oct 5, 2015 12:49 PM
gmcyukon
Oct 3, 2015 11:03 PM
old motorhead
Sep 29, 2015 08:22 PM
