milled heads .30, What length pushrods
Baltimore Whore
If the stock replacement lifter is now the ls7, what if you go to have a lifter fixed under warr?? They are going to stick the new ones in there.. There not going to replace all the PR's too.. From a quick search it seems that diff companies say to use a diff pre load on the lifters, also guys have switched to the new style lifters and still ran the 7.4 PR's with out any issue.. I have my heads milled .020 and am running 7.4 rods, without any probs or noise.. But it would be best to MEASURE since you are going with the new lifters and a decent mill job Again the lifter will be able to take up the diff + or -.
this motor is going in an S10, no warranty here...i think im going to just buy the checker and be sure dont want to buy everything over again, or hurt anything
Baltimore Whore
No the warranty thing was about if it was under and something happ. Even though the lifter are diff gm never said that it was mandatory to switch to a shorter one if a old(ls1) one was replaced... Like I said you it would be diff, get the checker...
PT's Slowest Truck
You make a good point in post #15...this isn't a warranty lifter replacement situation, it's a build with more variables
GrooveCityZ71
08-31-2015 12:05 PM
nickpc82
08-30-2015 09:18 PM
BennyB
08-01-2015 08:48 AM
lxcoupe
07-30-2015 02:42 PM
